Battery Draw
Old Aug 18, 2006 | 11:00 AM
95Vette's Avatar
Default Battery Draw
Hello all, I have a problem that I could a "jump start" on (pun intended).
I have 1995 Vette (31,500 miles) that recently ate a battery. I replaced the battery and the car's DIC is registering 14.5 volts (that's good, I think). To test for a battery draw I disconnected the negative battery terminal and hooked up a volt meter and was pulling 12.7-12.8 volts (that's bad). I know this a very broad question, but where should I begin to look for the battery draw? Do I start at the alternator? Is there any other component, switch, relay, etc. that is known to go haywire that I could check first? Or is this a "tear the whole car apart and test everything" problem?
Any help will be greatly appreciated. Thanks!!
Old Aug 18, 2006 | 11:48 PM
raisinbran's Avatar
Default RE: Battery Draw
you could start pulling fuses until you no longer have a draw.
Old Aug 19, 2006 | 12:19 AM
Hook a test light between battery cable and battery. If the light is lit, then it's easier to run down a draw. A voltmeter will fool you, because a 1/4 amp draw at 12.5 volts is not very much, but a bright or dim test light tells me more. As Raisin said pull fuses 1 at a time then replace them 1 at a time as u pull them. Watch your test light. Be sure and disable your interior lights if you keep your door open. Also, disconnect alternator leads beacause a shorted rectifier will draw a battery down. good Luck [8D]
Old Aug 19, 2006 | 05:20 PM
95Vette's Avatar
Thanks guys, I'll be sure to give these suggestions a try.
Old Aug 19, 2006 | 08:06 PM
Superdzzz's Avatar
mech is right. It will be a tedious process but with a buddy and a few cold ones you should be able to find it and have fun
FASTCARMAN
May 10, 2007 10:06 AM
crvttbass
Mar 31, 2006 09:25 PM
indycar
Oct 6, 2005 04:58 PM
wellsw
Aug 4, 2005 10:00 AM
