bose stereo
Old Jul 30, 2006 | 07:12 PM
tinyssnowplows's Avatar
Default bose stereo
I have a 91 convertible.Only the RR speaker worked.I changed the speaker amps and then they all woked.Now no sound comes out of speakers.The fuses are OK.The cdm box clicks on and off every time I turn the radio on and off.The radio chnges stations OK,and the clock and light are OK.Any clues??? CDM ???
Old Jul 31, 2006 | 02:30 AM
Default RE: bose stereo
I just changed sterieos on my '87 and had the same symptoms. come to find out that the power wire was not hoked up to the amps harness wire. I guess the amps have to be told to turn on with a seperate power sorce. as soon as I figured that out it worked fine. Hope it helps. cheers
Old Aug 1, 2006 | 12:45 AM
raisinbran's Avatar
yes there is atleast one amp-turn-on wire that must be plugged in. i believe it was pink on my 86. but if you just connect everything back the way it was, that should solve that. also at some point they put a radio relay in the bose systems. im not sure if you have one, or where its located, but that would definately be worth checking into.
Old Aug 1, 2006 | 02:06 AM
Thats right a little short Pink wire with an oddball clip. I just wired it to my antenna power wire so it would be powered up when the system came on. worked great. good luck brother.
Old Aug 1, 2006 | 09:24 AM
Thanks fo the help. I think the probem is in the CDM box.I took it out and sent it to United Radio in Syracuse,NY to be checked out. I will keep you posted as to how it turns out.Has anyone sent anything to United Radio before? How are they to deal with? Do they do good work?
Old Aug 1, 2006 | 11:13 AM
seen_alot's Avatar
just got my 89 back on the road after 2 year layoff.
stereo works fine but after 10 minutes front channels go out. Any suggestions?
Old Aug 2, 2006 | 01:28 AM
Not sure but I think the amps have cooling fans,(something is humming), if so maybe the amps are overheating because the fans don't work. But then again I might be stupid too.
Old Aug 5, 2006 | 09:10 AM
RADIO WORKS!!!Thanks for all the help.It was the CDM.I got it rebuilt at United Radio in Syracuse,NY.
Old Aug 5, 2006 | 10:03 PM
oldtvman's Avatar
I am an electronic tech, I worked on all types of consumer electroncs for over 25 yrs, I tell you BOSE built some of the worst audio amplifers, Bose in general was designed to work only with other Bose components, in my 84" have also have the Sony xplode and it works very well in this application
3BlkC4Ragtop
Sep 26, 2008 09:51 PM
khaki1967
Jun 9, 2007 09:53 PM
redvet
Nov 21, 2006 11:51 AM
njttz
Apr 17, 2006 02:00 AM
imb1987
Nov 20, 2005 05:32 PM
