Brake Frustration
I have been having some problems with my brakes. After the first 10 mins of driving i notice a problem with my brakes. At braking speeds of 25-40mph my brakes do not seem to grab correctly. They grind terribly to the point that it makes my stomach sick. However i took my 86 into les schwab today and the guys informed me that they could not find a problem. My pads and rotors are fine. I believe the problem to be with the calipers. Does anyone else have experience with this sort of issue?
RE: Brake Frustration
I have no experience with brakes but just so you won't get upset because no one posted in your thread - here is a big GOOD LUCK to you.
Double posting
What's the condition of your brake lines (internal failure)?????[sm=signs003.gif]
Not sure of what the condition of my lines are. I think im gonna hand the car over to my mechanic and see if he can fix it. Cause i know i wouldnt be able to fix it :)
could it be your abs pump that you hear they can make a bad grinding sound hope this helps
