Brakes are Fixed!!
Turns out that the "loose hub assembly" turned out to be just a rotor that needed to be turned. I got the front rotors turned for $40.00 and viola! No more shaking or knocking or tap-tap-tapping! Sweet!:D
[&:]Now I notice, though, that the breaks are a little mushy. I am now wondering ifthe break booster diaphram is leaking. It seems to get worse as the car warms up. I was also wondering ifthat could have something to do with the loss of power. Is this possible? |
RE: Brakes are Fixed!!
If you didn't change your brake pads when you had the rotors turned, they probably haven't seated yet.
Ok, Mech. I will give then some time to seat. I changed the pads about a month ago. Thanks for the info.
