Brakes are Fixed!!
Old Mar 10, 2008 | 10:32 PM
ZR1clone's Avatar
Default Brakes are Fixed!!
Turns out that the "loose hub assembly" turned out to be just a rotor that needed to be turned. I got the front rotors turned for $40.00 and viola! No more shaking or knocking or tap-tap-tapping! Sweet!
[&:]Now I notice, though, that the breaks are a little mushy. I am now wondering ifthe break booster diaphram is leaking. It seems to get worse as the car warms up. I was also wondering ifthat could have something to do with the loss of power. Is this possible?
Old Mar 11, 2008 | 06:23 AM
Default RE: Brakes are Fixed!!
If you didn't change your brake pads when you had the rotors turned, they probably haven't seated yet.
Old Mar 11, 2008 | 06:32 PM
ZR1clone's Avatar
Ok, Mech. I will give then some time to seat. I changed the pads about a month ago. Thanks for the info.
99hdtop
Apr 24, 2007 09:24 PM
Black86vette
Nov 21, 2006 03:34 PM
68 427
Sep 17, 2006 11:21 AM
rjensen
Sep 16, 2006 01:10 AM
CharlieM
Sep 10, 2006 11:46 PM
