C-4 Headlight Wiring
I have 77 views to my post and no answers,is there anyone out there who has a C-4 that can look at their wiring plug in under the hood and tell me what the correct color code is, I have the service manual but its not helping me Thanks for listing HELP
willing try to help ... ring my cell and I can walk you through it
Hope that helps Lawrence of so cal 909-717-5260 |
Lawrence of so cal Thanks for answering I will try to call tomorrow afternoon Thanks again Don
Tried your cell got leave a message left message but as of today no reply will try again tomorrow (Sat10/13) really need to get the lights working correctly Thanks Don
Dommo, best to leave message till I can replace this cell ... keep tryin
. these Vettes are plastic connected to metal frames ... corrosion etc = VLT night mares and draw gemlims live here Im repostered ! hope that helps L of so cal |
I think I have a simple solution just cant figure out where 2 wires go.Let me try to make this simple2 wires coming from the headlight motor 1 green and bkack and 1 gray and black, the female plug hanging from the light has 3 wires 1-Gray 1-green and 1-in the center which is white,now the male plug coming also from the light has 3 wires1-Gray 1-Green and 1-White,I assume the green & Black and the Gray & Black get wired to the Green and 1 to the Gray with wire nuts for the time being,that leaves no where for the White wire to fasten THIS IS THE DRIVERS SIDE,The passengers side is almost the same almostThe 2 wires coming from the light motors are 1-Gray & 1-GreenThe frmale wirs plug has 3 wires coming out 1-Green & White on the outside 1-Black & White in the center and a RED Wire on the other side,now the male plug has 3 wires 1-green & White on the outside 1-gray & white on the other side and a WHITE WIRE in the middle coming from the light. I do know thw lights and motors work in both directions but I can't get them to work properly,Maybe if some one could tell me where the White and Red Wires connect to, I think if you write a diagram as you read this it might make more sense and to top it all off the RED wire is HOT and so are one of the others
