C-4 Headlight Wiring
Old Sep 19, 2012 | 10:01 PM
Dommo's Avatar
Smile C-4 Headlight Wiring
I have 77 views to my post and no answers,is there anyone out there who has a C-4 that can look at their wiring plug in under the hood and tell me what the correct color code is, I have the service manual but its not helping me Thanks for listing HELP
Old Oct 10, 2012 | 01:21 AM
GT2Race's Avatar
willing try to help ... ring my cell and I can walk you through it
Hope that helps
Lawrence of so cal
909-717-5260
Old Oct 10, 2012 | 07:32 PM
Dommo's Avatar
Lawrence of so cal Thanks for answering I will try to call tomorrow afternoon Thanks again Don
Old Oct 13, 2012 | 12:30 AM
Dommo's Avatar
Tried your cell got leave a message left message but as of today no reply will try again tomorrow (Sat10/13) really need to get the lights working correctly Thanks Don
Old Oct 13, 2012 | 11:15 PM
GT2Race's Avatar
Dommo, best to leave message till I can replace this cell ... keep tryin
these Vettes are plastic connected to metal frames ... corrosion etc = VLT night mares and draw gemlims live here
Im repostered !
hope that helps
L of so cal
Old Oct 14, 2012 | 12:50 AM
Dommo's Avatar
I think I have a simple solution just cant figure out where 2 wires go.Let me try to make this simple2 wires coming from the headlight motor 1 green and bkack and 1 gray and black, the female plug hanging from the light has 3 wires 1-Gray 1-green and 1-in the center which is white,now the male plug coming also from the light has 3 wires1-Gray 1-Green and 1-White,I assume the green & Black and the Gray & Black get wired to the Green and 1 to the Gray with wire nuts for the time being,that leaves no where for the White wire to fasten THIS IS THE DRIVERS SIDE,The passengers side is almost the same almostThe 2 wires coming from the light motors are 1-Gray & 1-GreenThe frmale wirs plug has 3 wires coming out 1-Green & White on the outside 1-Black & White in the center and a RED Wire on the other side,now the male plug has 3 wires 1-green & White on the outside 1-gray & white on the other side and a WHITE WIRE in the middle coming from the light. I do know thw lights and motors work in both directions but I can't get them to work properly,Maybe if some one could tell me where the White and Red Wires connect to, I think if you write a diagram as you read this it might make more sense and to top it all off the RED wire is HOT and so are one of the others
Dommo
Sep 16, 2012 12:49 AM
bertsbassbox
May 31, 2006 01:14 AM
ltmalibu79
Sep 15, 2005 02:33 PM
jeepin45
Aug 23, 2005 12:44 AM
Dans endless project
Aug 16, 2005 03:09 PM
