A/C Magnetic Clutch Removal
Old Oct 30, 2006 | 10:20 PM
retiredSFer's Avatar
Default A/C Magnetic Clutch Removal
The A/C Magnetic Clutch on my 1993 40th Anniversary partially engages with the A/C turned off. My compressor has the hoses in front and there is less than 1" clearance between the hoses and the clutch. The service manual states that the hoses must be removed prior to removing the Magnetic Clutch. Has anyone removed the clutch without removing the hoses - is there enough room?
Old Jun 13, 2007 | 07:05 PM
7191race's Avatar
Default RE: A/C Magnetic Clutch Removal
I belive it can be dont without removing hoses. Try loosing compressor from its mount and then carefully angle it up and put a small 2x4 under it. then using the correct puller remove the pulley first remove the 10mm hex bolt. snap ring pliers to remove snap ring on clutch pulley, again use puller to remove, coil is behind clutch assm, also another snap ring then pull coil off etc, reinstall. it does help if you have another person helping you hold the compressor so you do not bend and damage hoses etc. just take your time it can be done, I've done it.
studlee2
Feb 21, 2008 12:10 PM
nappysvette
Aug 16, 2007 04:19 PM
trackzero
Dec 11, 2006 06:24 PM
jafone
Jun 12, 2005 11:43 AM
crausch
May 25, 2005 03:31 PM
