Correct temp ?
OK guys here is a question for all to answer what is the normal operating temp for an 89. Mine is all over the place . Normally around 185 to 195........but in traffic or town has run as high as 240 is that about right ? Thanks
RE: Correct temp ?
Sounds pretty normal to me. Doesn't have real good airflow if car is not moving. Might check your cooling fan in front to make sure it is working.
RE: Correct temp ?
was up, my temp. does that too. i always make sure my front airdam is straight and intact. i tell ya i just finshied the waterpump and its running alitte cooler. highest i seen was 233.
RE: Correct temp ?
Your reg operating temps are fine. My '87 work-in-progress never goes above 224. Even in 100 degree heat, no wind, high humdity and huge traffic jam.
Although, the cockpit could boil water in those conditions[:@] |
RE: Correct temp ?
i have a 180 stat and redline water wetter and a gallon of 40 below and green freez. and i run at 185 deg .when driving and 190-195 deg.when sitting and that is in a 93 lt1 engine and i live in florida. 98 deg most of the summer.i just make shure i have no air in system and full of water.make shure you fan is kicking on to at the right temp.:)
