Dash light
Help!
Put in a new coolant sensor on my '92 LT1. First unplugged the sensor(MAF?) on the intake, then took out the old coolant sensor and put in the new one. Refilled the lost coolant, put the intake back together and started the car before plugging in the sensor on the intake. Stopped the car, topped off the coolant, plugged in the sensor on the intake, started the car and now the "Service Engine Soon" warning on the dash will not go out. The car runs fine, except for the warning. Called the local Chev. dealer who would not help. Only advised me to bring it in in two weeks. Is there anything I can do to get the warning message to go out? |
RE: Dash light
Check your codes....Then post them back and *we* can help solve your problem.
RE: Dash light
Disconnect battery for 1 min, that will clear codes. Your probably set a coolant temp sensor code by starting the car with it not plugged in. BTW, it a CTS abb. MAF is for Mass Air Flow. [8D]
RE: Dash light
Thanx for responding. I not real up on the computer stuff. How do I get the "codes"?
RE: Dash light
Thanx for the response. Disconnected the negative batt. terminal for a min. or so. Reconnected andthe lite comes on again!
RE: Dash light
This is how its done ON MY YEARS COMPUTER SYSTEM. Yours may be different. I know autozone checks it for free but this you can do yourself.
First locate your car's alcl this component is located just below the instrument panel and to the left of the center console. Remove the plastic cover the first two slots to your right are the A & B slots for a drawing of the alcl module's picture is added below. The A slot is the diagnostic slot and the B slot is the ground slot. insert the computer key into these slots (with the engine off) this is very important...now only put the ignition key to on ( not start !!!) the check engine light will display a code 12 which is one flash followed by two flashes. this code will be flashed three times ..followed by the trouble code stored in your car's computer. what ever the code is it will be flashed three times. have a paper and pencil ready and write down the code . code 13 =1 flash followed by 3 flashes =>oxygen sensor code 14 =1 flash followed by 4 flashes =>coolant sensor code 15 =1 flash followed by 5 flashes =>coolant sensor code 21 = 2 flashes followed by 1 flash =>throttle position sensor code 22 = 2 flashes followed by 2 flashes=> throttle position sensor code 23 = 2 flashes followed by 3 flashes=> manifold air temp sensor code 24 = 2 flashes followed by 4 flashes=> vehicle speed sensor code 25 = 2 flashes followed by 5 flashes=> manifold air temp sensor code 32 =>egr system code 33 =>map sensor code 34 =>maf sensor code 35 => idle air control code 41 => cylinder select error code 42 => electronic spark control code 43 => electronic spark control code 44 => lean exhaust code 45 => rich exhaust code 51 => PROM code 52 => fuel calpak code 53 => system over voltage code 54 => fuel pump circuit code 55 => ecm code 62 => oil temp |
RE: Dash light
Thanx again, unfortunately I don't have a diagnostic tool, so I guess I'm at the mercy of the dealer. Oh well
RE: Dash light
Diagnostic tool? I use a paperclip...
RE: Dash light
or take it to autozone, they will do it for free.
RE: Dash light
Paperclip? Ah, American ingenuity! HOW?
Thanx |
