Dirty Runners and Intake.. What to check?
Old Feb 9, 2015 | 12:23 PM
Mac Rosel's Avatar
Default Dirty Runners and Intake.. What to check?
Guys,
I pulled the intake manifold off my '87 to fix a seeping gasket. The car was running great before this, just leaking a little coolant.
The intake runners were exceptionally soiled and when I pulled the intake, ports #2 and #3 were really dirty. I could physically wipe the sludge from the port. It was heaviest where the runners meet the mani.
Obviously, something is wrong but I'm not sure what to check at this point.
My first thought, these ports are where the coolant leak was and causing extra carbon build up. Any suggestions on what needs to be double checked, extra cleaned, etc...?
Old Feb 10, 2015 | 11:54 AM
Mac Rosel's Avatar
Default bump
bump!
Old Feb 11, 2015 | 02:50 PM
Most likely what you're seeing on the intake runners is caused by reversion. It is caused by gases that are kicked back into the intake during the overlap period when both valves are open. You will probably see this inside the throttle body also.
The 61 Man
Apr 6, 2008 08:48 AM
Sep 6, 2007 10:34 AM
grabie
Apr 28, 2007 05:44 PM
1990VETTE
Jan 27, 2007 10:50 PM
tiggerrick
Mar 11, 2006 11:46 PM
