Found the Vacuum leak, Where does it go?
Hey Guys!
I found the Vacuum leak, its on the pipe the goes to the PCV valve on the driver side of the motor( See Pic ). I place my finger over it and the RPMs drop down, Lots of suction,but I feel it goes some where and this place it goes probally isnt getting the suction it need, therefor causing my problems
I have looked around to see any other missing hoses cant see any. The Shop Manual doesnt say anything about this mystery missing hose either http://i174.photobucket.com/albums/w...C007141221.jpg
[IMG]local://upfiles/3562/DA79C9194CC1425D92DC7480C9F76B4E.jpg[/IMG]
I have looked around to see any other missing hoses cant see any. The Shop Manual doesnt say anything about this mystery missing hose either http://i174.photobucket.com/albums/w...C007141221.jpg[IMG]local://upfiles/3562/DA79C9194CC1425D92DC7480C9F76B4E.jpg[/IMG]
That goes up to the vapor cannister in the left front wheel well. It is the vacuum source for the evaporative emissions assembly. Does your car still have the vacuum diagram on the radiator housing?[8D]
I traced the hoses down by the canister. The only hose that wasnt going somewhere was a hosecoming out of the very bottom of thethe Cylinder shaped emmisions component that is further front., not the bowling ball looking thing. Is this the hose that needs to run up to the crank vacuum tube? Or is this just some kind of a run off waste hose?
IF it is the same one I dealt with, there are two manifold hoses that go into one just above the left side valve cover gasket. The receiving hose is larger and goes straight to the purge canister.
My last post wasnt very clear was it. There is only one little vacuum hose at the top of the round canister at thedriver sidein front of the wheel well. The Cylindercanister has a bunch, and seems to go to a electronic relay of some sort bolted right next to it.One hoseat the very bottom of the Cylinderis a piece of tube that is cut off. Is this cut off hose just a waste hose that needs to remain cut, or is this my vacuum leak that needs to go up to the tube just above the left valve cover?
There should be a couple metal tubes bolted to the frame rail left front. I would just put a vacuum plug on it for right now until you can figure out where it goes. I can take a pic tomorrow and post it for you. [8D]
