From 'ghetto' to landfill...
I got an oil leak.:(
This IS an oil cooler, right? Factory? Aftermarket? '94 LT1 The leak is while runnin', about a drop every 4-5 seconds, right at the yellow circle. Stops immediately when the motor is off.Just started - hardly any oil on the concrete, and the pan is full. Is it a junker? How much do you want to haul it away? What ARE we lookin' at here? I don't know this LT1 like I do the L98... Thanks. [IMG]local://upfiles/5243/4D747B241AF7491C84880E08C5047ED1.jpg[/IMG] |
RE: From 'ghetto' to landfill...
I think GM did away with the oil coolers on the C4 after the 1991 models. In 1992 they started using Mobil 1 and since it was synthetic oil they no longer put oil coolers on thecars.
What is that thing then? It's a cooler of some sort. And yellow stuff (not anti-freeze)is comin' from between the first and second fins there, where I got the circle...
[sm=smiley25.gif] |
Is that the best help I can get? Somebody has got to be able to give more guidance.
[sm=joke.gif]JUST KIDDING!:D All guesses absolutely welcome.[sm=smiley20.gif]Really! |
ORIGINAL: cwb What is that thing then? It's a cooler of some sort. And yellow stuff (not anti-freeze)is comin' from between the first and second fins there, where I got the circle... [sm=smiley25.gif] What's the liquid smell like? |
Does your car have RPO code KC4 (engine oile cooler)?
Do you have RPO code U04 (heavy duty radiator with transmission cooler)? |
ORIGINAL: KenHorse ORIGINAL: cwb What is that thing then? It's a cooler of some sort. And yellow stuff (not anti-freeze)is comin' from between the first and second fins there, where I got the circle... [sm=smiley25.gif] What's the liquid smell like? Not sure lees, I don't have a spec sheet.... Gonna' have to follow the line again. Stuff tends to disappear as it approaches the block area.[sm=smiley29.gif] |
Look under your lid to your console. Should be a list of RPO codes there.
ORIGINAL: LeesVette Look under your lid to your console. Should be a list of RPO codes there. Where's the key for build codes? Ya' gotta' google each one? [IMG]local://upfiles/5243/A16677A014DE49D993975632DCCB2E9C.jpg[/IMG] |
Gop to www.corvetteactioncenter.com. They have the build codes there someplace. I copied off them. I'd be more than happy to decode yours but I have to go to a meeting as of right now. If no luck I'll do it for you tomorrow as I 'm on vacation and don't have a whole lot to do. Check back later. Good Luck!
