From 'ghetto' to landfill...
Old Jul 23, 2007 | 03:37 PM
Default From 'ghetto' to landfill...
I got an oil leak.
This IS an oil cooler, right? Factory? Aftermarket? '94 LT1
The leak is while runnin', about a drop every 4-5 seconds, right at the yellow circle. Stops immediately when the motor is off.Just started - hardly any oil on the concrete, and the pan is full.
Is it a junker? How much do you want to haul it away?
What ARE we lookin' at here? I don't know this LT1 like I do the L98...
Thanks.
[IMG]local://upfiles/5243/4D747B241AF7491C84880E08C5047ED1.jpg[/IMG]
Old Jul 23, 2007 | 04:43 PM
LeesVette's Avatar
Default RE: From 'ghetto' to landfill...
I think GM did away with the oil coolers on the C4 after the 1991 models. In 1992 they started using Mobil 1 and since it was synthetic oil they no longer put oil coolers on thecars.
Old Jul 23, 2007 | 05:13 PM
What is that thing then? It's a cooler of some sort. And yellow stuff (not anti-freeze)is comin' from between the first and second fins there, where I got the circle...
[sm=smiley25.gif]
Old Jul 24, 2007 | 12:15 AM
Is that the best help I can get? Somebody has got to be able to give more guidance.
[sm=joke.gif]JUST KIDDING! All guesses absolutely welcome.[sm=smiley20.gif]Really!
Old Jul 24, 2007 | 09:12 AM
KenHorse's Avatar
ORIGINAL: cwb
[sm=smiley25.gif]
Transmission cooler perhaps? Although I wouldn't expect a leak from that to contain a yellowish liquid - I'd expect reddish.
What's the liquid smell like?
Old Jul 24, 2007 | 10:25 AM
LeesVette's Avatar
Does your car have RPO code KC4 (engine oile cooler)?
Do you have RPO code U04 (heavy duty radiator with transmission cooler)?
Old Jul 24, 2007 | 01:15 PM
ORIGINAL: KenHorse
ORIGINAL: cwb
[sm=smiley25.gif]
It's oil alright - fresh from a change. Looks good too, except for bein' OUTSIDE!!! Not sure if it's coming out of this cooling [thing] or not. But I can't tell how it is getting onto it; that is, if it's coming from another spot. And it has to be gettin' blown there, cause there'sabsolutely zerotrail to follow.
Not sure lees, I don't have a spec sheet.... Gonna' have to follow the line again. Stuff tends to disappear as it approaches the block area.[sm=smiley29.gif]
Old Jul 24, 2007 | 01:27 PM
LeesVette's Avatar
Look under your lid to your console. Should be a list of RPO codes there.
Old Jul 24, 2007 | 01:42 PM
ORIGINAL: LeesVette
Nonesuch. But I guess there's a motor in there...
Where's the key for build codes? Ya' gotta' google each one?
[IMG]local://upfiles/5243/A16677A014DE49D993975632DCCB2E9C.jpg[/IMG]
Old Jul 24, 2007 | 04:54 PM
beauchampgl's Avatar
Gop to www.corvetteactioncenter.com. They have the build codes there someplace. I copied off them. I'd be more than happy to decode yours but I have to go to a meeting as of right now. If no luck I'll do it for you tomorrow as I 'm on vacation and don't have a whole lot to do. Check back later. Good Luck!
