Headlights 89 Vette
Having problems with the headlights completing there cycle.Sometimes they work fine and other times they wont come all the way up or close all the way.Also if I assist them they will sometimes not lock and I will be driving and they will release and spin half way.Mainly on the driver side.Any input will be appreciated.Car is 89 vette coupeSteve
RE: Headlights 89 Vette
Sounds like the nylon gears in the motor. Real common problem witht these. Eckler's or just about any Corvette place sells a steel replacement gear set. You have to pull the headlight assembly and disassemble to get at the motor and gears. Good Luck! [sm=americanasmiley.gif]
this page saved me hundreds of dollars.
and it was fun. Make your C4 see well hope this link is ok.. if not, I'm sure it'll get fixed ; P |
