HOW DOES THE 4+3 TRANS WORK
Old May 13, 2005 | 06:04 PM
bbll8080's Avatar
Default HOW DOES THE 4+3 TRANS WORK
I HAVE 84 CORVETTE WITH THE 4+3 TRANS AND I'M NOT SURE IF ITS WORKING. CAN SOMEONE TELL ME HOW TO TELL IF IT IS WORKING.
Old May 13, 2005 | 07:41 PM
Patrick's Avatar
Administrator
Default RE: HOW DOES THE 4+3 TRANS WORK
hmmm...im sorry to say that I am not familiar with that one.
Old May 19, 2005 | 07:35 PM
LLL's Avatar
LLL
My 86 coupe also has the 4+3. Do you have a push-button on top of your shift ****? That button should engage/disengage the overdrive part of the unit.
The car needs to be up to operating temp before the OD will engage. If it does not 'drop down' into OD, try clicking the button to see if it reacts. My own OD switch is misbehaving, so I am having the switch replaced.
When operating properly, and turned ON, it will automatically drop into OD as you shift through the gears. If you decide to step hard on it, it will drop out of OD to normal drive for better acceleration. It may stay in normal for awhile before it drops back into OD.
If your button has no effect on the unit, maybe your switch is dead.
Another possibility: if you have a cold thermostat in the car (160), the coolant may not be getting warm enough for the unit to engage.
Another possibility: perhaps one of the sensors (coolant temp, speed, gear selection) that feed the OD controller may be dead.
Old May 19, 2005 | 08:57 PM
Patrick's Avatar
Administrator
very interesting...thanks for the info LLL!
Old Sep 13, 2005 | 07:52 AM
Racinguy32's Avatar
Has anyone tried to rebuild their overdrive unit? Mine is slipping, so I thought I might give it a shot. The alternative is to get a rebuilt one, so if anyone knows a reputable place to get one of those the information would be appreciated.
shooter71
Jul 1, 2012 07:19 PM
DanFrank76
Jun 1, 2012 06:32 AM
riley6riley
Jan 18, 2009 10:17 PM
dale
Apr 15, 2008 02:14 PM
TPR114
May 30, 2006 07:58 AM
