Idle problems
Old Sep 4, 2007 | 09:44 PM
  #61
lbelew's Avatar
Default RE: Idle problems
I've varied my timing from the recommended 6 btdc to 12 btdc. It runs smoother the further I advance it but the best running timming makes her ping. Reading the service manual they say I should have 34-39psi fuel pressure, I've only got 28 with vacuum.What kind of reading do you have on yours without vacuum. Also wondering if my cat is creating a backpressure issue. Thanks.
Old Sep 4, 2007 | 09:55 PM
  #62
rshiver's Avatar
I have about 37 psi with the vac unplugged. Listen to your exhaust, is it making a hissing sound if so I would suspect a clogged cat. Have you tried un plugging your sparkplug wiresone at a time to see if you have a cylinder misfiring? Have you done a compression test on all eight cylinders?
Old Sep 4, 2007 | 10:02 PM
  #63
Another pressure reference in the article, page 6, 3rd column, near the bottom:
below 35 psi, you get poor air/fuel mix, and idle and driveability problems. Is this the problem???
Old Sep 5, 2007 | 05:16 PM
  #64
elwood's Avatar
1990 with same problems should I try the same fixes or is the cars different? Can only get about 12 degrees advance before engine stumbles badly?
Old Sep 5, 2007 | 06:40 PM
  #65
rshiver's Avatar
On L98 engines the timing should be set at 6 degrees BTDC with the timing set connector unplugged. The timing set connector is located beside the distributor on the passengers side, it's a single, (brown and black I think) wire coming out ofa wiring harness. Be sure to reconnect it after the timing is set.
Old Sep 6, 2007 | 07:45 PM
  #66
lbelew's Avatar
Well guys, the saga comes to an end. Found the consolidated ground on the drivers side head had a nut that was close to vibrating off, tough to see, but still visible. Appreciate all of the good advice and a special thanks to rshiver.
Old Sep 6, 2007 | 08:03 PM
  #67
rshiver's Avatar
Congratulations man, glad you finally got it, now go and enjoy your Vette.
Cheers
Old Sep 6, 2007 | 11:59 PM
  #68
ORIGINAL: rshiver
Cheers
I told you !!! Wouldn't listen to me tho', huh? Noooooooooooooo... Vacuum leak, huh? Where did you get that idea anyway? Comic book? Horoscope? Psychic hotline???
Old Sep 7, 2007 | 12:29 AM
  #69
84corvetteC4's Avatar
....THANK GOD THATS OVER WITH[&:]
Old Sep 7, 2007 | 07:42 AM
  #70
rshiver's Avatar
[sm=jawdrop.gif]
