Idle speed
Old Oct 16, 2006 | 12:39 PM
mikenann's Avatar
Default Idle speed
What is normal hot idle speed for a 1987 C4?
Any one know?
Tanks
Old Oct 16, 2006 | 01:47 PM
thespannerboys's Avatar
Default RE: Idle speed
my 86 idles at 600-800 when warmed up, it used to surge up to 1500 and make this big Hissing noise when I hit the brake, but that only happens every now and agian, im sure that will be another story
[IMG]local://upfiles/3562/FCF28D2A90C94C55BAD735789330EA7D.jpg[/IMG]
Old Oct 16, 2006 | 02:09 PM
All2kool's Avatar
My '86 Cast Iron L98 idles between 800-900. Now and then, I have to tap the accelerator to get it to drop down from 1200-1300 though. Hasn't happened since spraying the throttle linkage with good ol' WD-40.
Old Oct 17, 2006 | 09:42 AM
Base idle is set with a torx head screw on throttle plate, but do not use that for setting normal idle speed as that is controlled by computer via idle control motor. Spanner, your hissing noise you are hearing might be the brake booster, which if the diaphragm is leaking will cause an idle surge. [8D]
Old Oct 17, 2006 | 04:18 PM
hmmm, yeah I knew it had to be some brake prob the servo or something, will this just go out one day leaving me on the side of the road? In other words should I go ahead and fix it?
Old Oct 17, 2006 | 05:10 PM
When it goes out, you will notice no power assist on your brakes. Won't leave you, but sure will make it hell stopping at a fast speed. [8D]
Old Oct 17, 2006 | 11:24 PM
sk8r20's Avatar
my 87 idles at 600rpm.
Old Oct 18, 2006 | 01:22 AM
Could be your Idle Control motor, need to clean throttle plates periodically for carbon buildup.
Old Oct 26, 2006 | 06:35 PM
Superdzzz's Avatar
My '87 work-in-progress idles at 600
Old Oct 30, 2006 | 08:32 PM
jmtrotzie's Avatar
where and how do you clean the idle control motor, mech ??? My 84 has had all the pollution taken off except for the air pump and she starts at around 2000 and slowly winds down to around 900 after a couple of minutes.
