Led Taillights
I got some LED Taillights for my 1990 c-4 I need to remove the whole taillight assembly.Any one got the best way to do this. THANKS Don
RE: Led Taillights
I think the best way is to remove the licence plate and reverse lights and reach into the area.
RE: Led Taillights
Thats the way I did mine....through plate area then once I had the inner light removed I stuck arm in through that hole to reach the outter. BTW, You will need a new LED flasher (EF32RL)...the old thermal one simply will not work. Corvette central has them in stock and you can find them at many truck stops. Ecklers is cheaper but its always on backorder http://www.ecklers.com/product.asp?p...p;dept_id=1149
