Led Taillights
Thats the way I did mine....through plate area then once I had the inner light removed I stuck arm in through that hole to reach the outter. BTW, You will need a new LED flasher (EF32RL)...the old thermal one simply will not work. Corvette central has them in stock and you can find them at many truck stops. Ecklers is cheaper but its always on backorder http://www.ecklers.com/product.asp?p...p;dept_id=1149
Inked Anarchist
Nov 2, 2012 09:06 PM
