Manifold air hoses...
Old Jan 3, 2008 | 11:17 PM
ken93vette's Avatar
Default Manifold air hoses...
I am removing the exhaust manaifolds on my 93 vette. I can not get the nuts out of the top of the exhaust manifolds that supply the airhoses. I have soaked them but they won't budge and the nuts which are brass are starting to bend. It is a 22mm wrench which they don't have in a flair wrench size.
Anyone have any suggestions?
Since I am going to be replacing them with LT Headers could I just cut the air tubes?
Thanks
Ken
Old Jan 4, 2008 | 06:12 PM
78buckshot's Avatar
Default RE: Manifold air hoses...
A very careful application of heat with an oxy-acetylene torch around the nut should do the job, try not to heat the nut, concentrate the heat on the manifold. You may be able to remove the manifold first then work on the A.I.R. tubes out of the vehicle.
riley6riley
Jul 3, 2008 05:09 PM
riley6riley
Jun 28, 2008 07:34 AM
avp0713
Apr 22, 2008 01:21 AM
harleymarkt
Mar 13, 2008 10:25 PM
classicman
Jan 1, 2007 10:39 PM
