My C4 wont start
Old May 19, 2005 | 01:56 AM
corvetteofcobts's Avatar
Default My C4 wont start
Have a security overide. Security light on dash panel is lit and car will not start. Any ideas on how to fix this?
Old May 19, 2005 | 11:36 AM
Patrick's Avatar
Administrator
Default RE: My C4 wont start
it just happened suddenly? is it a stock or aftermarket alarm system?
Old May 24, 2005 | 11:57 PM
It is the stock security system of a 1984. The security light on dash will light and I will not get juice to the starter. Any suggestions on possible problem and ways to fix/ bypass it. Problem was infrequent, but now is quite constant.
Old May 25, 2005 | 02:21 PM
Patrick's Avatar
Administrator
now, does it utilize a "clicker" style security system, or is it one that recognizes the correct ignition key? perhaps soemthing with the ignition switch or cylinder itself has gone bad? or the key?
Old May 25, 2005 | 08:42 PM
mxw128's Avatar
I've heard of problems with the VATS (Vehicle Anti-THeft System) chip which is in the ignition key having problems over time. I don't recall what the fix was (replacing the key or having to replace the entire cylinder) You probably have another set of ignition keys (the car usually comes with 2) Have you tried the other ignition key?
Old May 25, 2005 | 11:33 PM
Not for sure of the Security system Operational characteristics of this model year. I bought the car in 1994 and the keys supplied were cut from regular blanks (no embedded digi-chip). Worked great for years, than the problem arose. I believe I need to purchase a owner/technical manual for this year. This will establish a baseline of definite technical understanding.
Old Jun 15, 2005 | 04:42 PM
RaTTicus's Avatar
sounds like an aftermaket eprom chip was installed to get rid of the vats system,thats the only way a vet with vats will start without a chipped key. fuel injection specialties sells the eproms
for 175 stock set up. 210-654-0774 givem a call tellem what its doing they can help ya.
Old Jun 22, 2005 | 04:51 PM
STIX's Avatar
Take your key to the dealer. They will read it and give you the number of the chip.. If I recall it is 1 thru 10.
Call on of the aftermarket buys and order that number. I had the same problem on my 86. very easy to install.
takes less then 5 min. and under 20 USD
Old Jun 22, 2005 | 04:52 PM
STIX's Avatar
Forget what I said. I need to read more!!!! He said NO chip...... Good Luck!
Old Jun 24, 2005 | 12:59 AM
I believe the VATS system was picked up in the 1986- model years
