Newbie here!
seem to be havin' trouble with 'his' 94 ...he's put gas in it but it's still showing on reserve and the thing won't start...it will start with eather (??sp)...but once you stop sprayin' it ...it dies...he thinks it might be the fuel pump that gone in it...does anyone have any idea what might be wrong with it?
thanks Jen |
RE: Newbie here!
Sounds like fuel pump or supply voltage to the pump. If so, relay or fuse for source voltage.[8D]
RE: Newbie here!
thanks...and wherewould i find the fuel pump or supply voltage to the pump?...sorry if this has been asked before...what about the fact that even with fuel in it...it still says it's on reserve?...keep in mind this car never gets driven...it's 22,000K on it and it just sits...a waste to let it sit like that IMO...but it's not my car
Jen [IMG]local://upfiles/3365/F39EB82471474904B0CCF99BDF7E5F9A.jpg[/IMG] |
RE: Newbie here!
Sorry I can't help with that, but just had to pipe up about how gorgeous that car is! What a stunning Corvette... such low miles, too! Indeed, it should be driven! :)
RE: Newbie here!
thanks...it also has the removable hard top
RE: Newbie here!
how much gas did you put in it?
the fuel pump is underneath the filler neck. you must remove the rubber boot to get to it. you can unplug the connector to measure the voltage, and then you can pull the pump if needed. |
