Newbie here!
Old Sep 19, 2006 | 11:30 PM
94C4's Avatar
Default Newbie here!
seem to be havin' trouble with 'his' 94 ...he's put gas in it but it's still showing on reserve and the thing won't start...it will start with eather (??sp)...but once you stop sprayin' it ...it dies...he thinks it might be the fuel pump that gone in it...does anyone have any idea what might be wrong with it?
thanks
Jen
Old Sep 20, 2006 | 03:57 AM
Default RE: Newbie here!
Sounds like fuel pump or supply voltage to the pump. If so, relay or fuse for source voltage.[8D]
Old Sep 20, 2006 | 10:32 AM
94C4's Avatar
thanks...and wherewould i find the fuel pump or supply voltage to the pump?...sorry if this has been asked before...what about the fact that even with fuel in it...it still says it's on reserve?...keep in mind this car never gets driven...it's 22,000K on it and it just sits...a waste to let it sit like that IMO...but it's not my car
Jen
[IMG]local://upfiles/3365/F39EB82471474904B0CCF99BDF7E5F9A.jpg[/IMG]
Old Sep 20, 2006 | 01:08 PM
TopSpeed's Avatar
Sorry I can't help with that, but just had to pipe up about how gorgeous that car is! What a stunning Corvette... such low miles, too! Indeed, it should be driven!
Old Sep 21, 2006 | 12:06 AM
94C4's Avatar
thanks...it also has the removable hard top
Old Sep 21, 2006 | 03:17 AM
raisinbran's Avatar
how much gas did you put in it?
the fuel pump is underneath the filler neck. you must remove the rubber boot to get to it. you can unplug the connector to measure the voltage, and then you can pull the pump if needed.
AspDotNetGuy
Jun 19, 2006 02:29 AM
C6SunsetC6
Jun 19, 2006 02:22 AM
BLACKC6
May 23, 2006 09:01 AM
CorvetteNewbie
Jun 3, 2005 09:14 PM
AntiVenom
May 23, 2005 11:29 AM
