Newbie User - Brain Buster Problem
Hi all,
I am trying to change out the water pump on my 91 c4. I can manage all the work with no trouble except for 1 point. The AC bracket is a bear to get a handle on. There is 1 bolt (nut) behind what I believe are fuel lines and there is just no way to get a wrench of any kind into that space to loosen that nut. Is there any sort of trick or technique that can help get that nut off? The two bolts that go through the water pump AND the AC bracket are the only thing I'm having trouble with.
Thanks for any advice or help.
--z
--z
