Oil suggestions for my C4
I have a 1988 Corvette convert. with 70K miles on a stock engine. Recently I've read that the amount of ZINC in engine oil has been reduced to a level that would no longer protect the camshaft against eccesive wear.
I currently use Mobil Fully Synthetic 5W-30 but found out that it only contains 800 ppm of zinc, which is low. I was wondering if anyone else has heard of this issue, and what type of oil would you recommend? Thanks in advance. |
I'm not an expert by any stretch, but from I understand it's more of an issue with flat tappet cams, not rollers. I think yours has rollers. Wish mine did.
Originally Posted by AlottaChevy
(Post 61257)
I currently use Mobil Fully Synthetic 5W-30 but found out that it only contains 800 ppm of zinc, which is low. I was wondering if anyone else has heard of this issue, and what type of oil would you recommend? Thanks in advance. If you really want more Zinc in your oil, you can use a diesel rated oil (15w-40), such as synthetic Rotella, which I have used in my '92 LT-1 and it seemed to like it. I do not think the added Zinc benefited me any, but wanted to give it a try. To learn as much as you can about oil, jump over to BITOG.com. Happy reading. CG |
