Oil suggestions for my C4
Old Jun 17, 2009 | 08:01 PM
AlottaChevy's Avatar
Default Oil suggestions for my C4
I have a 1988 Corvette convert. with 70K miles on a stock engine. Recently I've read that the amount of ZINC in engine oil has been reduced to a level that would no longer protect the camshaft against eccesive wear.
I currently use Mobil Fully Synthetic 5W-30 but found out that it only contains 800 ppm of zinc, which is low.
I was wondering if anyone else has heard of this issue, and what type of oil would you recommend?
Thanks in advance.
Old Jun 25, 2009 | 07:36 AM
ms sux's Avatar
I'm not an expert by any stretch, but from I understand it's more of an issue with flat tappet cams, not rollers. I think yours has rollers. Wish mine did.
Old Jul 13, 2009 | 10:56 PM
Curious George's Avatar
Thanks in advance.
The Mobile 1 you are using is fine for your engine. Yes, Zinc in most oils nowadays has been reduced to around 700~800ppm. It is part of the recent SM rating.
If you really want more Zinc in your oil, you can use a diesel rated oil (15w-40), such as synthetic Rotella, which I have used in my '92 LT-1 and it seemed to like it. I do not think the added Zinc benefited me any, but wanted to give it a try.
To learn as much as you can about oil, jump over to BITOG.com. Happy reading.
CG
73coupe
Nov 16, 2006 05:33 PM
regchamp
Sep 10, 2006 01:58 AM
DarcyG
Jul 26, 2006 12:59 AM
ssa919
Jul 12, 2006 04:57 PM
zzz06r
Nov 9, 2005 03:41 AM
