one final question
Old May 3, 2006 | 11:27 AM
mercedes84black's Avatar
Default one final question
this morning i checked the voltages from my tps and later went and bought a code scanner, connect turned the key on and service light stayed on but no flashes, no codes, absolutely no changes at all, could this mean i need a new ecm. i don't see any loose wire or anything, also where would that computer brain be located if need be.
Old May 3, 2006 | 12:08 PM
Default RE: one final question
I beleive the ECM is under the hood above the battery. The scanner won't flash a code 12, then you are probably right.
Old May 8, 2006 | 11:12 AM
checked above the battery, no ecm located there. 1985 vette, any help......
Old May 8, 2006 | 12:40 PM
LeesVette's Avatar
On an 85 it should be under the passenger side dash.
Old May 8, 2006 | 12:44 PM
also is there any other ecm that'll fit like camaro or only the vette 1985 model, i have a friend that has a junk yard, if that is the case would the chip or something need reprogramming
PinnacleWax
Dec 30, 2014 04:38 PM
ednev
Feb 10, 2012 02:08 PM
jerseyc5
May 14, 2008 08:19 AM
Team 4R
Apr 15, 2006 10:16 PM
ViperGTS
May 9, 2005 06:57 PM
