Please help - I'm out of ideas!
Old Oct 16, 2010 | 10:05 AM
bugsym's Avatar
Default Please help - I'm out of ideas!
Having a problem with my bone-stock 89 6-speed. Once the car gets warm, there is no throttle response. Anything more than very light pressure on the pedal, and it just idles. If shut-off, it will not restart until it cools back down. When cold, it will run fine at part throttle, but if you put your foot into it a little, it acts like a "hi-speed" miss. Fuel pressure at the rail is 30 psi, I changed the fuel filter, and the injector pulses look good. There are no codes, and everything looks fine on the scanner. I've read a few other posts and it seems that others have experienced this problem, but I haven't seen a solution.
Like I stated, the car starts fine when cold, and idles perfectly, so I don't think it's a vacuum leak issue. I've been chasing this for about a month and am at the end of my rope! Any advice would be appreciated.
Old Oct 18, 2010 | 08:25 AM
beauchampgl's Avatar
I had a similar problem with my 93. It turned out to be the distributor. That was an LT-1, though. You should ahve an L-98, I thinjk. I would suggest you find a repair shop with an engine analyzer (Sun machine). They hook it up to the car and you should have your answer in no time flat. That's how I found out what my problem was after fighting the car and changing out perfectly good parts for over a year. Good Luck.
Old Oct 25, 2010 | 06:01 AM
Try unplugging MAF. That will put it in a backup mode. See if throttle response improves any.
mjrock62
Jun 8, 2007 07:07 AM
Bepollard
Jul 27, 2006 08:53 PM
itzfrank
Jan 12, 2006 02:46 PM
roflowj
Sep 30, 2005 11:43 AM
blbcklt1_tb
Jul 31, 2005 03:11 AM
