PVC Valve
I have a stock '90 coupe. Recently noticed pvc valve and connecting hose gone.
Turns out it had just came loose and fallen down below valve covers. I replaced it back in appropriate hole in valve cover. The question is, should I go ahead and get a new one? They're only a couple of bucks and I'm not sure how old this one is. Not much experience in this area. Thanks. |
RE: PVC Valve
you can never go wrong with putting a new one. also check the condition of the hose
RE: PVC Valve
Maybe just keep checkin' that it stays in place, and then if nothin' goes wrong, consider replacement only as part of routine maintenance...
RE: PVC Valve
Gotcha..... Thanx..
