Ram air/ programmer
I want to put a Votex Ram Air from Mid America on my '96. But I also want to get a Hypertech programmer to. I understand that there is a problem with using the two units together because the HP is set up to work with a stock set up and will not change the fuel/airmix ratioand the car will run on the lean side. Is there a way around this or should I just forget one or the other or both if no noticeable gain will be realized.Ifinstalling oneis the case which one would be the best touse on my stock engine.
http://www.mamotorworks.com/corvette?frame=3.724 |
RE: Ram air/ programmer
First off, I doubt a "ram air" intake will do you any good on a stock or near stock engine, the stock air intake is pretty wide open. However, with a Hypertech chip, or anybody elses programmer, make sure the supplier of the program knows exactly how your engine is set up, chances are any company that has been around a while has enough experience to supply you the program to work with a vehicle set up like yours. However, if you plan to make future modifications, you may need to get a differrent program after more mods are made.
I got one of those. It warped a little from the heat. Looks cool though!:DYou can do both and it won't make above 10 horsepower IF even that which I doubt. If you like the intake for the look though and the "whoosh" sound it makes, then go ahead and do it. I did.:)
The only "true" ram air/cold air intake your going to get is the one that you have to cut a hole in the front bumper.
ORIGINAL: LeesVette The only "true" ram air/cold air intake your going to get is the one that you have to cut a hole in the front bumper. |
