rear view mirror ball socket
My rear view mirror is real loose. the ball socket is the problem. Is there a fix?
RE: rear view mirror ball socket
You sure it's the ball loose in the socket? Or maybe the part that slides down onto the glued-onto-the-windshield part.
Theres a tiny allen screw that secures the slide onto that glued piece... |
Mine has same problem. It was worse with the Targa top off. I tightened the tiny
screw as tight as would go but the vibrations would shake/shift mirror. It's not as bad with top in place..Tightens roof/less vibration. I was thinking either learn to live with it or get complete mirror replacement. Saw it advertised in some Corvette Parts Wishbook but don't remember which one. |
it is a roadster and is not glued onto the windshield.
