REVISE " NO HEAT 1993 "
I POSTED THE " NO HEAT 1993 " THE OTHER DAY , FOUND OUT IF I DISCONNET THE PLUG IN AT THE A/C COMPRESSOR I GET BETTER HEAT. NOW MY QUESTION IS WHY DOES THE A/C COMPRESSOR STAY ENGAGED ALL THE TIME , UNLESS UNPLUGGED OF COURSE? IT DOES NOT MATTER WHAT SETTING ON THE TEMP CONTROL I HAVE IT?
A light bulb that won't cut off (unless it is unscrewed) would NOT be hard to diagnose. First thing you would do is pull the switch, and see if it breaks the circuit when switched. A/C is the same, with a few more switches.
Might take a while, but since it is NOT intermittent, all you heed is a multimeter, and wire schematic.
