Rookie Question
Old May 20, 2007 | 07:03 PM
RudeDog's Avatar
Default Rookie Question
I have a '90 Corvette, stock engine not ZR-1.The car has 61M on it and I don't have complete
repair records. My problem is that the engine has developed a valve/engine rattle. When I excellerate
a little strong I hear a rattle coming from the engine. Kind of like a knock but more like a rattle.
I use only BP Gas ethyl rated at 93 octane. Just got engine oil changed for 2nd time with Mobile Synthetic. Have put in injector cleaner but did not let the cleaner go thru full cycle of tank due to expense of full tank fill-up. (Kept filling up after 1/2 tank.)
I don't know when last tune up was done. Think this is next step? Appreciate advice. Thanx
Old May 20, 2007 | 07:30 PM
78buckshot's Avatar
Default RE: Rookie Question
I don't have much experience on the injected engines but it sounds like the knock sensor is at fault.
Old May 20, 2007 | 08:14 PM
A tune up surely wouldn't hurt. The noise you're talkin' about, can be a timing issue.
Old May 20, 2007 | 10:55 PM
Have you throttled up usingthe linkage with the hood up? You might zero in on the tunes this way...
How many miles on the vehicle?
Old May 21, 2007 | 06:23 AM
Sounds like EGR is not working and what you are hearing is detonation. Also, check your ignition timing by disconnecting Set Timing connector and then check with a timing light.
Old May 21, 2007 | 06:37 AM
RudeDog's Avatar
Thanx y'all. Appreciate timely replies....
Old May 25, 2007 | 07:08 PM
RudeDog's Avatar
Have appt. next Weds to have mechanic tune up my '90 and especiallly check the timing. Hope that
will take care of it. Probably going the plugs, wires etc. he said could do with AC Delco parts and get
her done for $250.00 - $300.00 (He takes plastic thank God, after the new Borlas and labor I'm Tap City.
Again, I appreciate everyones input.
Old Jun 4, 2007 | 06:33 AM
RudeDog's Avatar
Well, got the tune up but still a little knock/rattle. Mechanic advised then it probably is bad gas. Suggested I put some Octane 104 in the gas tank. I bought the Octane 104 Maximum and added it.
So far so good.......
Old Jun 4, 2007 | 10:04 PM
It's not the gas. By putting 104 in, you are probably covering up the problem. Did you have the EGR system checked out? EGR valve not functioning will cause detonation that you are hearing.
Old Jun 5, 2007 | 05:43 AM
RudeDog's Avatar
Thanx mech259. If this hasn't cured it (haven't driven it since week-end) the EGR Valve
will be my next stop. Appreciate info.
