Starting Problems... again...
Old Jul 5, 2007 | 01:41 PM
95trplblkandtan's Avatar
Default Starting Problems... again...
Whats up guys... got another starting issue here with my 95. It started happening very rarely, but now almost everytime i get in to start my car. When i turn the key i here nothing but a click, i turn the key a few more times and the same thing happens... occasionally the engine will start to turn over then stop, then after a few more "clicks" the engine will start. My guess is a loose connection somewhere or a bad solenoid. Not sure where all to look for loose connections... i checked the obvious connections at the battery, those are good, anyinputs??
Old Jul 5, 2007 | 01:45 PM
JoeVetteman's Avatar
Default RE: Starting Problems... again...
If you have a bad starter solenoid you might as well replace the whole starter.You can get one with a lifetime guarantee.Can't do that with just the solenoid.They're not too expensive either.I do believe the LT-1 cars use a gear reduction starter too.
Old Jul 5, 2007 | 02:19 PM
what is the best way to get to the starter motor??
Old Aug 5, 2007 | 10:51 PM
84corvetteC4's Avatar
bad starter solenoid or bad ground
Old Aug 6, 2007 | 07:00 AM
red90vettesc's Avatar
My car was doing the same thing, turn the key and a click, it ended up being a cracked gear in the reduction set. Getting the starter out is a real pain the ***. I had to drop the front Y pipe on the exhaust of my car, to get it out.
Physco82
Aug 28, 2007 11:29 PM
vrooomm
Feb 7, 2007 06:48 PM
red90vettesc
Dec 31, 2006 12:29 AM
maberry72
Jul 29, 2006 12:36 AM
footdoc
Jun 30, 2005 11:34 PM
