stumble at lower rpms
Old Jun 28, 2008 | 08:11 PM
scooterman's Avatar
Default stumble at lower rpms
Here's my issue- hoping for advice. My 94 has recently developed what I can best describe as a stumble ar miss at low rpms. no codes or pending codes. I put plugs in it about 10k ago. I was advised to replace the wires and did, but it didn't help. It seems to run fin when cold but after warm up when you accelerate from a stop it stumbles at about 1000 rpms before it shifts into second and if I'm in traffic just keeping up at lower speeds and rpms it just doesn't seem to run good. I'm beginning to wonder if I have an injector going bad. I just can't tell if it's fuel related or ignition related. Advice as always is appreciated
Old Jul 2, 2008 | 11:11 AM
LeesVette's Avatar
Default RE: stumble at lower rpms
Have you ohmed the injectors? Checked fuel pressure? I would hook up a fuel pressure gauge and tape it to the windshield. Drive it and see what the pressure is while its in the process of stumbling.
Old Jul 3, 2008 | 06:25 PM
With what you have done, it may be fuel related. The real way to find out is to have an injector balance test performed to see if there is any discrepancy in the performance of each injector. It can't be done on you car without a fuel pressure gauge and an injector tester to fire each injector 50 times to measure fuel pressure drop on each cylinder.
1996corvetteCE
Feb 29, 2008 09:59 PM
july349
Oct 14, 2005 07:27 PM
july349
Oct 8, 2005 02:01 AM
radar
Sep 15, 2005 10:15 PM
sl0010
Jul 13, 2005 10:11 AM
