sys on dash
Old Jun 26, 2007 | 10:39 AM
Jordan's Avatar
Default sys on dash
my 90 vette flashes sys on the dash, where it says my gas milage. does anyone have any seggestions what this might mean. thanks for any help.
Old Jun 26, 2007 | 12:11 PM
LeesVette's Avatar
Default RE: sys on dash
You need to pull codes.
Old Jun 26, 2007 | 01:49 PM
Viscount's Avatar
A majority of "SYS", are battery relatedI would check the battery for full charge & dirty connections, etc.
Hope it's that simple.
Old Jun 26, 2007 | 04:20 PM
Jordan's Avatar
thanks for the help, i will check into that.
Old Jun 26, 2007 | 04:38 PM
Notorious's Avatar
ORIGINAL: Viscount
[sm=exactly.gif] Most often this is related to low voltage, for whatever reason.
Old Jul 23, 2007 | 09:58 PM
Paul Spickard's Avatar
If you have a interior bulb missing it will flash sys on the dash.
Old Jul 24, 2007 | 12:02 AM
ORIGINAL: Paul Spickard
Paul, if you pulled the bulb while working on the lights-staying-on problem in your thread, you might be onto the problem there. That is, IF 'sys' can mean things other than low system voltage.
Betcha!?
Old Jul 24, 2007 | 04:55 PM
whytry's Avatar
I had the original stereo replaced with a Alpine stereo and my "sys" light has been on every since
Old Jul 24, 2007 | 05:38 PM
LeesVette's Avatar
ORIGINAL: whytry
Thats because you or the installer didn't add a resistor in the wiring that eliminates that. If you want the instructions I can send them too you. There was a TSB that came out on it a few years ago. I have an Alpine also.
Old Aug 2, 2007 | 01:37 AM
dpop24's Avatar
Please post or send directions. I've had the SYS error since I installed an aftermarket stereo! It's not hurting anything it's just annoying.
