Tail happy C4
Old Mar 28, 2017 | 09:15 AM
Airboss 52's Avatar
Default Tail happy C4
We are setting up an 89 C4 track car. First day out, we noticed that she got pretty "tail-happy" on light fuel loads. We currently have the rear end set up with 0 camber. What is a good race set up for rear end alignment?
Negative 2? More?
Old Mar 29, 2017 | 05:04 PM
Oversteer can be reduced by increasing front sway bar or decreasing the rear sway bar. I would suggest starting w/ the factory spec for negative rear camber and go from there.
Did you chalk the tires to determine if you had optimum tire pressures?
