temp sensor
Took the 93 out yesterday and the outside temperature reading said 72degrees. It was a LOT hotter than that. Drve over some RR tracks and the reading went up to 89, which was more like it. So I guess there is a loose wire or connection from the sensor to the readout in the instrument cluster. Where is it and where does it go? Will I have to dismantle half the car to get at it? Thanks in advance.
RE: temp sensor
It's located on the lower right hand side of the radiator. You can access it from the outside I believe.
It's a small black box. |
RE: temp sensor
That sensor is called the sun load sensor and it is on top of the dash, center grill.
