temp sensor
Old Sep 7, 2007 | 09:23 AM
beauchampgl's Avatar
Default temp sensor
Took the 93 out yesterday and the outside temperature reading said 72degrees. It was a LOT hotter than that. Drve over some RR tracks and the reading went up to 89, which was more like it. So I guess there is a loose wire or connection from the sensor to the readout in the instrument cluster. Where is it and where does it go? Will I have to dismantle half the car to get at it? Thanks in advance.
Old Sep 7, 2007 | 09:36 AM
Viscount's Avatar
Default RE: temp sensor
It's located on the lower right hand side of the radiator. You can access it from the outside I believe.
It's a small black box.
Old Sep 8, 2007 | 06:29 AM
That sensor is called the sun load sensor and it is on top of the dash, center grill.
ken93vette
Aug 16, 2008 09:12 PM
imb1987
Feb 10, 2008 06:23 AM
MyC5WillEatYouAlive
May 15, 2007 09:44 PM
chargedvette02
Feb 18, 2007 01:44 AM
deepsquat
Oct 4, 2006 02:45 AM
