Tilt wheel in an 85 ?
I just wanted know where the button to adjust the steering wheel height is located on an 85 vette. Right now the wheel is a little too high and I would like to lower it.
Thanks, |
RE: Tilt wheel in an 85 ?
Do you mean your tilt steering wheel?
If you are referring to your tilt wheel, my friend, on our car the lever is located between the turn signal stalk and the digital dash board, on the left side there.... when we bought ours, the stalk for the tilt adjustment was broken, we had it fixed before we took delivery of it. The replacement unit is a rather short stalk, in comparison to the turn signal one.
On your 85 you have both tilt and telescope for the steering wheel...there is a lever just below the steering wheel which will allowing you to push the wheel in and out
the telescope control is right under the center of the wheel and the tilt is bettween the turn signal and the dash:D:D:D
