Tilt wheel in an 85 ?
Old Jan 31, 2007 | 05:49 PM
TealC4's Avatar
Default Tilt wheel in an 85 ?
I just wanted know where the button to adjust the steering wheel height is located on an 85 vette. Right now the wheel is a little too high and I would like to lower it.
Thanks,
Old Jan 31, 2007 | 06:06 PM
TopSpeed's Avatar
Default RE: Tilt wheel in an 85 ?
Do you mean your tilt steering wheel?
Old Jan 31, 2007 | 07:23 PM
TopSpeed's Avatar
If you are referring to your tilt wheel, my friend, on our car the lever is located between the turn signal stalk and the digital dash board, on the left side there.... when we bought ours, the stalk for the tilt adjustment was broken, we had it fixed before we took delivery of it. The replacement unit is a rather short stalk, in comparison to the turn signal one.
Old Jul 6, 2007 | 03:46 PM
85c4Don's Avatar
On your 85 you have both tilt and telescope for the steering wheel...there is a lever just below the steering wheel which will allowing you to push the wheel in and out
Old Aug 6, 2007 | 05:49 PM
84corvetteC4's Avatar
the telescope control is right under the center of the wheel and the tilt is bettween the turn signal and the dash
Gohot
Jun 19, 2012 09:42 PM
73vettenet
Feb 28, 2011 09:38 AM
jeff s
Jan 20, 2008 10:00 PM
ryan
Aug 20, 2005 05:20 PM
Doctor K
Jul 3, 2005 09:22 PM
