Under Hood Lights
Old Nov 7, 2006 | 07:51 PM
eugene1617's Avatar
Default Under Hood Lights
Are the lights under the hood supposed to come on when hood is raised ? If so is there more than 1 fuse or what else would cause them not to come on ? Thanks Dave
Old Nov 7, 2006 | 08:24 PM
All2kool's Avatar
Default RE: Under Hood Lights
Uh...burned out bulbs?
Old Nov 7, 2006 | 08:30 PM
eugene1617's Avatar
Bulbs are ok. so is fuse on passenger side inside. Anything else outside under hood.
black86coupe's Avatar
umm yea...I would hope that its the bulbs considering that theres not much that makes them up.
Old Nov 8, 2006 | 01:15 AM
Inside each light is a little mercury switch on one end of the bulb. If you have a test light you can check one end with the mercury switch to see if you have power. Those lights were kind of notorious for getting corroded and the clips and connections just might need a good cleaning. (What I did to mine). Also grounds were not clean and tight to. Both lights ground on the driver side frame rail just below the hinge. [8D]
Old Nov 8, 2006 | 02:39 AM
raisinbran's Avatar
what exactly triggers the lights to come on when you raise the hood? maybe there is a problem in the switch?
Old Nov 8, 2006 | 08:29 AM
mypetu39's Avatar
Can anyone tell me what the stock number(?) or reference number is for these two bulbs is? Both of mine have been out for years now, and the suppliers want to know the "numbers" for them. Mine is an 87 Vette, and the bulb for under the hood is a "strange" looking bulb that "pushes" into the socket(s). Thanks for any i9nfo.
mypetu39
Old Nov 8, 2006 | 09:21 AM
Take a bulb with you to the parts store. They should ba able to find a match for you.
Old Nov 8, 2006 | 11:05 AM
eugene1617's Avatar
Thanks for all the help ! I'll check out all tips and let you all know results my next day off. Which is Friday.
Old Nov 8, 2006 | 01:56 PM
ARCTIC94's Avatar
In my '94, there is a second fuse just in front of the left front tire. It is easy to access and I frequently remove it at car shows so my battery don't die.
