VACUUM
I repaced distributeer water pump plugs and wires now I have a problem with vacuum, I cannot switch vents on ac and can't locate vacuum lines, where the heck is the booster? engine idles at lower rate and kills at fast stops, also due to probable vacuum leak
RE: VACUUM
I believe you have a 93. Check under the pass/side fuel rail cover. There are vacumn lines, etc., located there.
