VACUUM
Old May 12, 2008 | 12:38 AM
wldbill's Avatar
Default VACUUM
I repaced distributeer water pump plugs and wires now I have a problem with vacuum, I cannot switch vents on ac and can't locate vacuum lines, where the heck is the booster? engine idles at lower rate and kills at fast stops, also due to probable vacuum leak
Old May 12, 2008 | 06:46 PM
Viscount's Avatar
Default RE: VACUUM
I believe you have a 93. Check under the pass/side fuel rail cover. There are vacumn lines, etc., located there.
81GAVette
Technical Diagram Help
Oct 17, 2006 07:18 PM
mikenann
Aug 23, 2006 11:35 PM
bighank
Aug 18, 2006 03:31 PM
srizzutto
May 27, 2006 10:21 PM
Daveloves
Dec 16, 2005 02:32 AM
