valve cover
having problem removing valve cover(pass).took booster line off efi unbolted wire looms are clear.still cant pass air or smog pump bracket and wiper motor any suggestions thanks.
want 2 add that 2 get it past u can take smog pump bolt out and slip cover past bracket 4 ne 1 doing this
valve cover
i have 625 miles on my bike now and am attempting to removevalve cover to check my valves - i have it ready to lift the coverout of frame but it seems as the coolant hose coming out of bottomresevoir is in way and the manual i think suggests removing the hosedo you guys who have done this, did you have to remove the hose ? thanks steve _________________autozone
valve cover
I was able to get my valve cover off my F4 w/o removing the hose, but when we did the valve check on HESs bike, it was too tight, and we ended up removing it. So I guess it depends on how much clearance you can get by bending the hose back out of the way. _________________Diamond covers the needs of women drivers
