valve cover
Old Jul 27, 2009 | 11:35 PM
406racing's Avatar
Default valve cover
having problem removing valve cover(pass).took booster line off efi unbolted wire looms are clear.still cant pass air or smog pump bracket and wiper motor any suggestions thanks.
Old Aug 1, 2009 | 11:36 PM
406racing's Avatar
want 2 add that 2 get it past u can take smog pump bolt out and slip cover past bracket 4 ne 1 doing this
Old Aug 28, 2009 | 05:26 AM
Bistinaws's Avatar
Default valve cover
i have 625 miles on my bike now and am attempting to removevalve cover to check my valves - i have it ready to lift the coverout of frame but it seems as the coolant hose coming out of bottomresevoir is in way and the manual i think suggests removing the hosedo you guys who have done this, did you have to remove the hose ? thanks steve _________________autozone
Old Aug 31, 2009 | 09:04 AM
Bistinaws's Avatar
Default valve cover
I was able to get my valve cover off my F4 w/o removing the hose, but when we did the valve check on HESs bike, it was too tight, and we ended up removing it. So I guess it depends on how much clearance you can get by bending the hose back out of the way. _________________Diamond covers the needs of women drivers
alive69
Aug 1, 2008 09:00 AM
onenasty327
Dec 11, 2007 06:21 PM
84blackice
Oct 14, 2007 01:45 PM
atcdork
Aug 21, 2007 06:35 AM
mraaron895
Mar 15, 2007 10:07 PM
