Why do my headlights open when I turn on my parking lights?
I have a 95 vette i just bought, and when ever I turn on my parking lights the headlights open up! The head lights do not come on unless I turn the switch to headlights. This is driving me Crazy!! Can anyone out there please enlighten me as to what I need to do.
RE: Why do my headlights open when I turn on my parking lights?
well the first thing i would check is the light switch.it could be shorted out,it could have a short when you put on your parking lights and it by passing and turing on your head lights.if it not the switch check the relays for the lights,you can buy a switch at eckler corvvette or you local part store for around 20.00 dollars.[sm=signs003.gif]
[IMG]local://upfiles/1664/64979960EE104B12A248AF226C6141DE.jpg[/IMG] |
Have to check the wiring schematic, but I think the light doors are controlled by body control module. Will check at my shop and post as soon as possible. [8D]
Thanks, I will check the relay, I was trying to remove the headlight switch but one I did not have a socket that had the walls thin enough to remove it... Thanks for the info
