Window wont roll down
Hi . newbie here I just got my first Vette,A Red 92 I got it home and the drivers window wont go down. passenger side is fine. anyone got any idea's?
RE: Window wont roll down
Start by checking power source & then the switch. Has a 30A circuit breaker in the I/P fuse block.
If the other window is working it's probably the switch? |
Thanks, I will check it this weekend
Could be a broken window ribbon.
ORIGINAL: Thunder Thanks, I will check it this weekend If you hear a clickin' sound, the drive gearin' is worn like lee said. But if you DON'T, itCOULDstill be the drive... |
The window regulator in yours is all metal gears. More than likely, you have a bad motor or switch.
It could be electrical. My passenger window didn't work for 2 weeks, then started working again. I discovered since the weather stripping is bad on that side (at the time), it was leaking water inside the door and possibly causing a short. I'm guessing after the water evaporated the short was no longer there and presto: I haven't had problems since.
Either that, or my car carries the uncanny ability to regenerate itself ;). Nice year and color of vette BTW.Mine's a twin, sort of. |
[sm=welcomesign.gif]
If you can rule out the switch, then it is more than likely the motor on yours.[:@] A dealership and/or repair shop will try to tap you for the whole "shebang" motor and armature assembly. However, all you have to do on a C4 is drill out the rivets on the old motor and order a new motor from one of the MANY online sites. $70 versus $400. Buy rivets and tool, $30 at Home Depot. Find somebody patient and competent enough to deal with a Vette door:D Or ask and I have the procedures for unassembly and reassembly for the window motor[8D] With pictures:D[8D]:D David[sm=icon_cheers.gif] |
When we first got our 93 the passenger side window wouldn't roll down. The fuse was OK. Got some tuner/contact cleaner at Radio Shack and gave the switch a shot or two. Worked fine after that. Hope your fixis that simple.
OOOOOOOOOOKKKAAAAAAAAAAAAYYYYYYYYYYYYYYYY......... ..
What's up with the eye????????????????????????????????????[sm=smiley8.gif] |
