Window wont roll down
ORIGINAL: Thunder
Thanks, I will check it this weekend
If you hear a clickin' sound, the drive gearin' is worn like lee said. But if you DON'T, itCOULDstill be the drive...
It could be electrical. My passenger window didn't work for 2 weeks, then started working again. I discovered since the weather stripping is bad on that side (at the time), it was leaking water inside the door and possibly causing a short. I'm guessing after the water evaporated the short was no longer there and presto: I haven't had problems since.
Either that, or my car carries the uncanny ability to regenerate itself
Nice year and color of vette BTW.Mine's a twin, sort of.
.Nice year and color of vette BTW.Mine's a twin, sort of.
[sm=welcomesign.gif]
If you can rule out the switch, then it is more than likely the motor on yours.[:@]
A dealership and/or repair shop will try to tap you for the whole "shebang" motor and armature assembly.
However, all you have to do on a C4 is drill out the rivets on the old motor and order a new motor from one of the MANY online sites. $70 versus $400.
Buy rivets and tool, $30 at Home Depot.
Find somebody patient and competent enough to deal with a Vette door
Or ask and I have the procedures for unassembly and reassembly for the window motor[8D] With pictures
[8D]
David[sm=icon_cheers.gif]
[8D]
When we first got our 93 the passenger side window wouldn't roll down. The fuse was OK. Got some tuner/contact cleaner at Radio Shack and gave the switch a shot or two. Worked fine after that. Hope your fixis that simple.
